Best Tool Bags and Boxes Android Central 2020
When it comes to storing your tools, there are more than enough different options to make your head spin. From boxes to bags and everything in between, there is a bag or box that will fit your needs. We have found some of the best of both tool bags and toolboxes that will make carrying or storing your tools a breeze.
Just the basics: WORKPRO 16-inch Tool Bag with Water Proof Base
Staff Pick
The WORKPRO Tool Bag will be a reliable option for most as it's made from 600D polyester for superb durability. As for where to put your tools, there are 8-inner pockets, along with 13 external pockets. Plus, the bag itself sports a wide-mouth opening, making it easy to find the right tool.
$20 at Amazon
Lift comfortably: Dewalt TSTAK II Flat Top Tool Box
Dewalt is a brand name that everyone recognizes and for good reason as the company makes some of the best tools and accessories. The TSTAK II Flat Top Tool Box is fantastic for those who need a box on the go. Plus, you can use this with other TSTAK products for better storage of different boxes.
$20 at Amazon
Save your shoulders: Klein Tools Tradesman Pro Backpack
It can be cumbersome to throw a toolbag on just one shoulder throughout the day as you go from location to location. The Klein Tools Tradesman Pro Backpack makes life easier, as you'll get the standard back straps, along with a handle on the top. There are a total of 39 different pockets in this backpack, including specific slots for screwdrivers and others.
$90 at Amazon
Getting started: Plano Grab-N-Go Tool Box
Measuring in at 26-inches wide, the Plan Grab-N-Go Tool Box will be large enough to carry many of your tools. There are also two removable organizers included, along with a lift-out tray for easy access to commonly used tools. Then, you can close up the toolbox and take advantage of the heavy-duty latches on the front.
$30 at Amazon
All the pockets: CLC LeatherCraft 50-pocket Tool Bag
The CLC LeatherCraft Tool Bag is truly the end-all-be-all if you have a boat-load of tools to carry. With 50 different pockets and vertical pockets for quick access, you can load this bag up to the brim with everything you'll need. The bag is even big enough to carry select power tools without worrying about forgetting them behind.
$73 at Amazon
Improved security: GearWrench Black Steel Tool Box
It can be quite costly to replace misplaced or stolen tools, and the GearWrenceh Black Steel Tool Box helps to combat that. There is a keyed center lock so that you can lock the toolbox when it's not in use. Additionally, there are three slide-out drawers, along with a section underneath the lid.
$59 at Amazon
Easily accessible: Jackson Palmer Medium Tool Tote
The Jackson Palmer Tool Tote is a bit different, as this bag is entirely open for the easiest access to your tools. There are a total of 27 pockets to take advantage of, along with a handle and a shoulder strap. Jackson Palmer has also included iron buckles and reinforced stitching for heavy-duty usage.
$34 at Amazon
Better organization: Makita Interlocking Case
If you are someone who has a boatload of tools, then the Interlocking Case from Makita might be for you. The reason for this is the fact that it can easily stack and won't fall over thanks to the interlocking latches. Plus, you can organize the toolbox to your liking with foam cutouts for better-secured storage.
$44 at Amazon
Carry your tools with ease
Finding the right tool bag can be a tough task, but with the WORKPRO 16-inch Tool Bag, you get a great "multi-purpose" bag. There are a total of 21 different pockets to take advantage of, along with a wide mouth at the top for easy access. The WORKPRO Bag also is made from 600D polyester, adding to better durability so you won't have to worry about the accidental bag breaking at some point in your workday.
Those looking into a toolbox instead of a bag will want to look no further than the Dewalt TSTAK II Flat Top Tool Box. The latches on the front will ensure that your tools stay secured, and locked into place, without them falling out while going from job site to job site. In addition to having two handles to take advantage of, you can stack this box with other options from the TSTAK family of toolboxes.
We may earn a commission for purchases using our links. Learn more.
