LG Volt for Virgin Mobile USA
LG's Volt is the latest LTE-enabled device to make its way onto Sprint's two prepaid carriers, Boost Mobile and Virgin Mobile. The Volt is the US carriers' variant of the LG L90, which has been available internationally since March. The LG Volt is the first device to bring Sprint's Spark "enhanced LTE" service to the prepaid market.
As far as the hardware is concerned, you're getting a 4.7-inch qHD screen (960 x 540), 1.2 GHz Qualcomm Snapdragon 400 SoC, 1 GB RAM, 8 GB internal memory, microSD card slot (up to 64 GB), 3000 mAh battery, 8 MP camera with BSI sensor, LTE, Wi-Fi 802.11 b/g/n, Bluetooth 4.0 and NFC connectivity along with Android 4.4 KitKat.
The device also includes LG's Knock Code, which is an upgraded version of KnockOn, a feature that allows you to lock and unlock the device by tapping twice on the screen. With Knock Code, you can create a personalized unlock code pattern that is more secure when compared to KnockOn's standard double tap feature. In addition to Knock Code, the Volt features Next Radio, a utility that allows you to browse nearby FM radio stations, QuickRemote, QuickMemo, QSlide and other LG exclusive utilities.
The Volt is available starting today for $179.99 on Virgin Mobile and Boost Mobile
Source: Virgin Mobile, Boost Mobile
