If you're making use of Kindle for Android on an ICS equipped device then you may have noticed it has some slight issues with freezing when you launch it. If you never noticed it -- awesome but if you have, there is now an updated version available the addresses the issue. It's labeled as v3.3.2 and you'll find it readily available in the Android Market right now. Download link is past the break.
- Filed under:
- News
- Tags:
82(forum posts)
