With a brand new season of Fortnite comes brand new challenges, and Season X has changed up the way players will be taking them on. For the recently leaked Boogie Down set of missions, one of the missions for this week will have you dancing in front of a bat statue, a way-aboveground pool, and a seat for giants. Finding the locations might not be too difficult for a seasoned veteran, but we've found the locations just in case you might be stuck.
Knowing the challenge
Dancing in front of the three locations is a reasonably straightforward challenge, but players won't be able to do it until Thursday at 9:30 a.m. ET, when the game resets. Because the challenges leaked, however, we're able to take a look at where you'll need to go to give you a heads up.
The most important thing to note about this challenge is that one of the locations - the aboveground pool - is located on the new floating island, and therefore isn't in the same spot all the time. The island moves, so simply look for its location on the map and find it. For the first portion of this challenge, players won't have to do anything but dance in front of the three locations. For the prestige challenge, however, you'll need to dance in front of all three in the same match.
Getting to these areas shouldn't be hard, but if you're stuck, make sure to refer to the map below for their locations.
Where to find a bat statue, a way-aboveground pool, and a seat for giants in Fortnite
  1. Jump into any game mode of Fortnite's Battle Royale. I'd suggest Solo or Team Rumble, as they are the best for challenges like these.
  2. The Bat Statue can be found right at the front of the broken down castle overlooking Haunted Hills.
  3. The way-aboveground pool is located on the new floating island, and is therefore constantly moving. Simply look for it on the map and land there.
  4. The Seat for Giants is south of Shifty Shafts, in front of the gas station and house. It's a giant wooden chair, so it's hard to miss.
Once you finish up, you'll be all done with that challenge, and can either get started on some of the other missions for this week or finish up the match you're in.
If you're looking for more challenges to do, you can always check out the full list of Boogie Down Missions to see what you've missed, still need to complete, or simply head back to the main menu to prepare for the next challenge. There are tons to do this week, so you'll be busy for a bit!
Take your gaming to the next level
KontrolFreek FPS Performance Freek Vortex Thumbsticks ($17 at Amazon)
When it comes to video games, making sure you have the advantage is key. These thumbsticks will ensure that by giving you better grip and better aim through three distinct level grips.
Konky PlayStation 4 Charging Dock Stand ($10 at Amazon)
Having your controller die on you in the middle of a gaming session is rough, so make sure you never have that happen again, and keep them charging at all times.
PowerA DualShock 4 Charging Station ($16 at Amazon)
Worrying about battery life can be stressful, but it doesn't have to be. Make sure your controllers are always ready to play by keeping them charged at all times!
We may earn a commission for purchases using our links. Learn more.
