Best Accessories for Ring Video Doorbell 2022
By Jeramy Johnson , Christine Persaud published
Ring's various video doorbells provide a great way to make your home a bit smarter, but you can make them even more powerful with the best of the best Ring doorbell accessories. While Ring includes everything you need to get up and running out of the box, it never hurts to go beyond the basics. Some items are available for specific Ring doorbell models only, so pay close attention before buying.
Amazon Echo Show 10
You can use the Echo Show 10 to see who is outside your door, and as the newest Show device, this version is better than ever thanks to its 10.1-inch HD screen that actually moves on its base to follow you, always keeping you in frame or the screen facing you. You can also talk to whoever is outside through the Echo Show 10 and hear them back.
Corner Kit for Ring Video Doorbell 3/3 Plus, 4
Every doorway is different, and you may need to get creative with how you mount your doorbell for it to be effective. This corner mount from Ring gives you up to a 30-degree horizontal angle, so your camera pays attention to where it should. This model works with the Ring Video Doorbell 3 and 3 Plus.
KIMILAR Angle Mount
If you need to change your vertical angle instead of your horizontal one, this kit is for you. Here you get three wedges to angle your Ring Doorbell Pro, this time at 5, 10, and 15 degrees. Screws, drywall sockets, and even a little screwdriver are included so you can have the mount installed in no time. This option is available as a wedge or corner kit.
Ring® Rechargeable Lithium Quick-Release Battery Pack
It never hurts to have a spare battery for your Ring products. This kit includes a rechargeable battery pack and a USB charging cable. The battery should last 6-12 months, though it takes seven hours to recharge. It is compatible with the Ring Video Doorbell (Gen 1), Peephole Cam, Stick Up Battery Cam (2nd and 3rd Gen), and Spotlight Cam Battery.
Dechiany Ring Battery Charger, Dual Port Charging Station
If you run your Ring doorbell off of a battery (even if just on backup), you'll need to charge those batteries every so often. This dual charger by Dechiany can charge two Ring backup batteries at a time for your video doorbell or Ring cameras.
Power Over Ethernet Adapter, Video Doorbell Power Supply
Keep your Ring Video Doorbell Elite (or Ring Stick Up Cam) continuously powered up with first-party power over an Ethernet PoE adapter. No more surveillance interruptions just to recharge your batteries!
Solar Charger Mount for Ring Video Doorbell 3/3 Plus, 4
Ring's video doorbell batteries can last for months, depending on your usage. Still, if you want to extend the battery life even longer and minimize charging sessions, the Solar Charger add-on is a charger and mounting bracket in one. It works great on both the Ring Video Doorbell 3 and 3 Plus.
Ring Chime (2nd Gen)
Your doorbell won't do you any good if you can't hear it throughout your home. The Ring Chime's speaker plugs into any power outlet to let you hear whenever someone is trying to come inside. The Chime lacks a microphone, though, so you won't be able to talk to that person.
Ring Chime Pro (2nd Gen)
This does everything the Chime does but also serves as a Wi-Fi extender. Now, this doesn't work as an extender for your smartphone or tablet — it's only for Ring devices, so you can hear alerts in that secluded back corner of your home. It also has a built-in night light.
Knock knock, ding dong
Ring's video doorbells are great on their own, but like with all smart home tech, they get so much more capable once you add some accessories. Of course, none of these are mandatory, but we personally like the Amazon Echo Show 10 for its ability to let us see who's at our door and engage with them (or not) from our sofa. We don't even need to get up since the Echo Show's screen will rotate to face us!
Of course, if you want to take your actual doorbell up a notch, consider the Ring Corner Kit or KIMILAR adjustable mounts to make sure that you can actually see who's at the door. Don't forget to keep your doorbell powered with something like the Ring Solar Charger Mount. Whatever accessories you add will no doubt only complement your supremely useful Ring video doorbell.
Remember that while Ring is one of the top brands in the video doorbell market, if not the top brand, there are alternative video doorbells worth exploring if you don't think that the Ring brand is for you.
Jeramy is proud to help *Keep Austin Weird* and loves hiking in the hill country of central Texas with a breakfast taco in each hand. When he's not writing about smart home gadgets and wearables, he's defending his relationship with his smart voice assistants to his family. You can follow him on Twitter at @jeramyutgw.
Get the best of Android Central in in your inbox, every day!
Thank you for signing up to Android Central. You will receive a verification email shortly.
There was a problem. Please refresh the page and try again.
