The fingerprint sensor on the Honor 8 is not only fast, but it is also extremely useful. Beyond being able to secure your phone, it can also give you quick and easy access to your notifications, and more. One of the great features Honor built into its software is Smart Key, a way to set up the fingerprint sensor to do even more.
  1. Tap the Settings icon from the notification shade.
  2. Tap on Smart assistance.
  3. Scroll down and tap Smart Key.
  4. Tap to change the options for Press, Double press, and Press and hold.
You can set each option to do something different, or only set one of them if you want. This will give you quick and easy access to things like the camera, your favorite social media apps or anything else that you use regularly.
