If you've just blown £500 or so on a shiny new Samsung Galaxy S III (or committed to a new 24-month contract to get a subsidized model), you'll want to do everything you can to prevent it from knocks and scrapes. One of the first cases to appear for the S III on the European launch day was the official clear TPU case, manufactured by Anymode. This is a basic flexible plastic shell that matches the curved design of the S III, and features raised areas along the sides to allow easy pressing of the power button and volume rocker. And you've also got cut-outs for the LED flash, camera, rear speaker, mics, headphone jack and microUSB port. The case extends around the edge of the device, covering the corners, which are most susceptible to damage from falls or sudden impacts.
Texture-wise, the case is typical of most TPU offerings -- it's flexible and a little plasticky, without awkward rubber-like feeling that characterizes some silicone cases. Its flexibility means it's easy enough to put on or remove from the phone, while the patterned area inside the case grips the back of the phone securely to avoid slippage.
As it's transparent, you won't be upsetting the aesthetics of the Galaxy S III too much. The extra thickness isn't all that noticeable during regular use, or when the two are pocketed. Our only design concern stems from the slightly rough edges of the case, likely caused by the molding process, though that's true of many cases of this kind.
The clear TPU case for the Samsung Galaxy S III is available for around £15 from retailers in the UK. We've got more photos after the break.
- Related devices:
- Filed under:
- Tags:
- case
- case review
- clear case
- galaxy s iii
- galaxy s3
- review
- s3
- samsung
- tpu
89(forum posts)
