If you've got an HTC ThunderBolt on Verizon, chances are you spend a lot of time charging the thing. I will never again be plugging in my ThunderBolt, however. Picked up Verizon's wireless charging battery cover for it recently and paired it up with an inductive charging pad -- it uses that newfangled Qi charging system -- and couldn't be happier.
Here's how it works: You pop the wireless charging cover onto the ThunderBolt. It looks nearly identical to the stock cover -- same soft-touch coating and HTC logo, though it is just a tad bigger. Not nearly as big as the ThunderBolt's extended battery, but you will notice a very slight bulge.
Then there's the Energizer Inductive Charging Pad. It's just as simple. Plug the AC adapter into the wall, then put the phone on top of it. It's that easy. But probably the best thing about it are the Qi logos, which help you properly position the phones for charging. You really don't have to think about it at all. And as an added bonus, there's a USB port on the back of the pad, so you can plug in a third device without taking up an extra wall plug. Nice.
We're using the ThunderBolt here, but Verizon has wireless charging backs for the Droid 3, Revolution and Droid Charge as well, and there are third-party backs for some other devices, too.
We've got video and a couple more pictures after the break.
- Related devices:
- Filed under:
- Tags:
2438(forum posts)
