If you need a sturdy hard-shell case for your HTC Thunderbolt, the Body Glove Snap-On Case might be just the ticket. It's a two-piece case, with a rubberized outer shell over a hard plastic protective case, that wraps around all four corners. You have the option of using the included belt clip, or switching out the removable knob for the flush insert for pocketability. The belt clip also doubles as a sturdy, adjustable vertical kickstand.
The case itself goes on easily, and once it is on you'll need a flat screwdriver or a coin to remove the interlocking pieces. Just place either in the slot on the lower right, and twist. This one's not coming apart on its own. Make no mistake -- this case adds in a bit of bulk, but it's providing a lot of protection, too. The case lip keeps the screen off the surface if it's laying face down, and is plenty thick enough to protect the camera lens cover when placed on its back. The cut-outs for the ports and controls are well placed, and they are all easy to use while the case is on, and ample space is provided for all the noise cancelling microphones. Of course, the kickstand is cut-out, too.
If you're looking for a sturdy case that gives the maximum protection from bumps and dings, and want or need a non-slip texture, you can grab the Body Glove Snap-On Case for the Thunderbolt for $27.95 from the Android Central store. Hit the break for more pics.
- Related devices:
- Filed under:
- Tags:
5331(forum posts)
