The individual Arlo Pro 2 home security camera is down to $129.80 on Amazon right now marking a new low price for the add-on camera. The camera has sold for more than $190 on its own in recent months, though it averages around $160.
Monitor more
Arlo Pro 2 add-on camera
Hook up more Arlo Pro 2 cameras for a clear view all around your property.
$129.80 $158 $28 off
If you've invested in the Arlo Pro 2 home security system through something like this 2-camera kit, you can add an extra camera or two with the above deal. You do need the base station that comes with one of those kits, but at this price it's worth buying the smaller starter kit and adding individual cameras separately.
The Arlo Pro 2 smart home wireless HD security cameras can be used indoors or outdoors to keep watch over any angle of your home - they're weatherproof and even include night vision so you'll be able to see even when it's dark out. The best part about these cameras though is that they're wireless allowing you to set them up easily wherever you'd like. They're also compatible with Amazon Alexa and Google Assistant, so you can use them with with devices like the Echo Dot and Google Home Mini, giving you the ability to view your live video streams with a voice command.
Get More Arlo
Arlo Ultra
This post may contain affiliate links. See our disclosure policy for more details.
