There are lots of VPN options available and picking the right one can be a bit difficult. The prices vary, some lock you into long commitments, and some are just not as feature-rich as others. Right now, you can grab one year of StrongVPN access for just $52.49, which breaks down to just $4.37 a month. If you aren't quite sure whether you need a VPN or not, you can try it out for just one month for only $7.50 right now if you want. Both of these are thanks to a limited-time coupon code, WIREGUARD25, so don't miss out.
Safer browsing
StrongVPN
This is another great option if you're in the market for a VPN to secure your computer a bit more. You can try it out for a month, or go all-in and grab a one-year subscription.
25% off for first billing cycle
With coupon: WIREGUARD25
StrongVPN is compatible with quite a range of devices, including iOS, Android, macOS, Windows, Fire TV Sticks, and more. The subscription gets you access to over 950 servers in 26 different countries and 46 cities, and there are 59,500 VPN IPs. You can run up to 12 simultaneous connections, and each one will have access to the "best available location" feature to ensure you get the best speeds. There are no speed limits or logging from StrongVPN, so your data is your data, and no one else's. That includes if you're on a public Wi-Fi network.
This deal won't stick around for long, so be sure to try it out now before the coupon code expires!
Get ready for Black Friday
We may earn a commission for purchases using our links. Learn more.
