Sony Xperia XA Ultra specs
After releasing the Xperia X, XA and X Performance at MWC 2016, Sony followed up the three mid-rangers with a larger variant, the XA Ultra, packing a huge display and big boost in front-facing camera specs. Outside of the larger screen and improved camera things are basically the same internally as the standard Xperia XA, which isn't necessarily a bad thing when it comes to mid-range devices. You can check out all of the specs for the Xperia XA Ultra right here.
Swipe to scroll horizontally
CategoryXperia XA Ultra
Operating SystemAndroid 6.0 Marshmallow
Display6-inch 1920x1080Mobile BRAVIA engine 2Super Vivid mode
ProcessorMediaTek MT6755 octa-core64-bit
Storage16GB
ExpandablemicroSD up to 200GB
RAM3GB
Rear camera21.5MP with Exmor RSHybrid autofocus, HDR
Front camera16MP with Exmor R88-degree wide angle lensFlash, OISAutofocus, HDR
Chargingmicro-USB
Battery2700 mAh
ConnectivityWi-Fi, Bluetooth 4.1, NFC, GPSMiracast, Google Cast, DLNA
WaterproofingNone
Dimensions165.1 x 78.7 x 7.6 mm
Weight189.9 g
ColorsWhite, black, lime gold
Andrew Martonik
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
