Save big on Kmashi's 15000mAh battery pack
Kmashi's 15000mAh power bank is on sale at Amazon with the coupon code DNWS3612, dropping the price to just $12.50 from its usual $60. If you are looking for a portable battery to keep in your purse, backpack, in the car or just to have around, you'll want to check this one out. The 15000mAh battery inside should be enough to charge most phones anywhere from 4 to 6 times, and tablets 3 to 5 times.
If you need some extra power, this is a deal for you. With the two USB ports, you'll be able to charge two devices at the same time. Remember, you need to use coupon code DNWS3612 to get the full savings.
$12.50 at Amazon
This post may contain affiliate links. See our disclosure policy for more details.
