Choose between the CanaKit Raspberry Pi 3 B+ 32GB Ultimate Starter Kit or Super Retro Gaming Kit with both on sale for $69.99 at Woot. The kits sell for around $90 on Amazon. This is one of the best deals we've ever seen for either version. The only real difference between them is the Super Retro Kit has a case designed to look like a Super Nintendo and comes with some game pads.
One day deal
Build your own little computer and use it for retro gaming, collecting security footage, or any number of things. But be aware that these kits are $20 off for today only.
$69.99 $89.99 $20 off
The Raspberry Pi is an open platform computer that can be used for any number of things. Here are some of the more popular examples of things you can do, including setting it up for retro gaming or a smart camera.
If you go with the Ultimate Starter kit, you might want some retro game pads anyway. Or you'll want to get a larger SD card. We've also got a break down of some of the best accessories for these kits, too.
The starter kit includes the 1.4GHz quad-core Model B+ Raspberry Pi 3, a 32GB microSD card, a 2.5A USB power supply with micro USB cable, custom LEDs you can install, and more. You'll get a high-quality case, an HDMI cable, two heat sinks, and both a reference card and quick start guide. The Retro Gaming version comes with two retro game pads and a retro case. The microSD card comes loaded with NOOBS (or Download Wizard for the Retro kit), which is a simple operating system installer with the Raspbian operating system designed for Raspberry Pi machines.
We may earn a commission for purchases using our links. Learn more.
