Best clear cases for Samsung Galaxy Note 5
Sometimes having a unique, flashy or busy-looking case can be a stylish accessory for your phone, but there's nothing better than a minimalist, clear case that shows off the sleek beauty of your Samsung Galaxy Note 5.
While there are dozens of options for you to pick from, here are a few great ones to check out if you're looking for a durable and reliable clear case for your Samsung phone.
Spigen Ultra Hybrid
Spigen Ultra Hybrid
Made from tough polycarbonate and a flexible TPU bumper, the Spigen Ultra Hybrid is a great quality case and a perfect fit for the Galaxy Note 5.
A raised bezel protects your phone's screen, while all buttons and ports are easily accessible, so you don't need to slide it on and off every time you're charging it.
Even though the Ultra Hybrid is a clear case, you can choose to get clear or colored accents for the TPU bumper, like black and mint green.
See at Amazon
Ringke Fusion Crystal Clear
Ringke Fusion
If you're looking for a well-made clear case for your Galaxy Note 5, consider taking a peek at the Ringke Fusion Crystal Clear case.
Super thin and snug-fitting (plus it comes in eco-friendly packaging!), the Ringke Fusion is an anti-scratch case with a transparent TPU bumper that wraps around your phone for full protection.
All buttons and ports are easily accessible through dust caps that are there to prevent debris from blocking the ports of your Galaxy Note 5.
See at Amazon
Spigen Neo Hybrid Crystal
Designed with a bendable, tight-fitting, clear TPU shell and a hard polycarbonate frame that comes in three different colors (silver, gold, and blue), the Spigen Neo Hybrid is a great minimalist case for your Galaxy Note 5.
You get full access to all ports, as well as metal-plated buttons with the Hybrid Crystal, while the TPU material, which is not as slick, smooth, and slippery as polycarbonate, keeps your phone secure in your pockets and firmly in your grasp.
See at Amazon
CellularVilla Clear Cushion
By far the least expensive option on this list at around $7.99, the Clear Cushion case from CellularVilla is an affordable, great quality case for your Galaxy Note 5.
The Clear Cushion is designed with dual-layer, shock absorbing material, so if you drop your Galaxy Note 5, you won't have to worry much about your phone screen shattering.
Made from an anti-stretch material, the Clear Cushion has cutouts throughout, so you have full access to all buttons and ports. Did we mention that this case adds little to no bulk to your Galaxy Note 5?
See at
Naked Tough case
Naked Tough case
Thin, smooth, and durable, the Naked Tough case from Case-Mate is a tough – yet stylish– option for your Samsung Galaxy Note 5.
This hard-shelled case is designed with a shock-absorbing bumper to protect your Galaxy Note 5, while metal buttons add a bit of style to the case's minimalist overall look.
Designed to be super slim and nearly invisible on your phone, the Naked Tough case is well worth checking out if you're looking for a thin, transparent accessory.
See at Case-Mate
What's your pick?
Is there a clear case for the Galaxy Note 5 that you're absolutely in love with? Let us know in the comments below and we'll check it out!
This post may contain affiliate links. See our disclosure policy for more details.
