Verizon has started pushing an update with the latest Android platform security patches to the Samsung Galaxy Note Edge. Once the update is installed, Galaxy Note Edge users should find themselves current with the March security patch and on software version LRX22C.N915VVRU2BPA4.
As the update has just begun rolling out, it may not show as available for everyone right away. If you haven't yet received a notification to update your Verizon Galaxy Note Edge, you can go ahead and manually check for the update via the Settings menu.
Discuss the update in the forums
