The ultra-rugged Kyocera DuraForce XD will be available to T-Mobile customers starting May 11 for $449. If you are harsh on your phones, or work in an environment that puts your phone at risk daily, this may be the one for you. Featuring a large 5.7-inch display, the phone is IP68 water and dustproof. You can leave the phone in up to six feet of water for 30 minutes, and it will still function properly afterwards.
On the inside, you've got an unnamed Snapdragon 1.6 GHz quad-core processor, a 3700mAh battery to get you through the day and more. If you are in need of a rugged smartphone that has some powerful specs and will withstand your beating, this is the one you should be checking out.
