Android Forums at Android Central
Customization options really are one of the finer, loved points of Android. Being an Android user allows for a wide variation of customization options. Some like the multitude of different applications which change the look and feel of your device while others like to dig deeper and change everything by loading up custom ROMS. Since many folks here love ROMS, hop on into the forums and check out some of what users have been posting. If you're a ROM developer, set up shop and share your goods.
If you're not already a member of the Android Central forums, you can register your account today.
There are 3 comments. Add yours.
jescobe82 says:
FIRST!
Do not forget the TrulyEpic ROM!!!! It is a great ROM and my EPIC is running fantastic. Since this site is the main location for support of this ROM, I think it should be supported more in the writings of the site!!!!!
You're absolutely right.. I'll be sure to include it at some point.
