New at ShopAndroid.com: Seidio SURFACE Extended Battery Case for Verizon Galaxy Nexus | Android Central
Shop: Insanely Cheap Wireless Plans | Chromebooks: Asus Flip | Acer R13
Sponsored Post
This deal is expired
Seidio SURFACE Extended Battery Case for 3800mAh Extended Life Battery for Veriz
Just a quick heads up for those of you who picked up the 3800 mAh extended battery for the Verizon Galaxy Nexus -- ShopAndroid.com now has in stock the Seidio SURFACE Case to fit that honkin' battery. It's made of a durable plastic and has Seidio's soft-touch coating and, most important, it protects your phone while using the larger extended battery.
And if you're still on the fence about the larger battery, check out our hands-on post for a look at how big it is.
