In Short
LeTV, a company that is primarily known for its streaming services in China, has announced the first smartphone that utilizes Qualcomm's brand-new Snapdragon 820 processor. LeTV's first offering is no slouch, as it packs some serious specs inside. On the front, you'll immediately notice the 6.33-inch 2K display that is powered by a 3400mAh battery inside its metal chassis.
Alongside the Snapdragon 820, LeTV has included 4GB of RAM inside the Le Max Pro, along with a new Adreno 530 GPU. On the rear you'll find the fingerprint sensor as well as the 21-megapixel camera, that in our limited testing seemed to perform quite well indoors. The Le Max Pro will launch running Android 6.0 Marshmallow, but with it being destined for China, it does not run any Google services.
