The latest Instagram for Android update is now available for download in the Google Play Store. This update will be higher priority for those of you out there making use of devices with a front-facing camera. As noted in the change log, it corrects some issues when using the advanced camera option as well as some problems with the reliability of photo filters for certain Galaxy Y and Ace devices. If you fit into either of those sections, or just want to ensure you have the latest installed, you can grab the link below.
- Filed under:
- Tags:
105(forum posts)
