HTC Rhyme
If you are the proud owner of the HTC Rhyme, but have had a few gripes with the device's software, you will be happy to know Verizon will soon be pushing an update. Unfortunately this update will not be the one that brings Ice Cream Sandwich to the device, but HTC and Verizon have managed to squeeze quite a few changes in this one. Some of the changes in this latest update include --
Device Features
  • “ Ringtones” has been replaced with “Edit Home” when the Menu key is pressed
  • on the home screen.
  • Updated signal strength meter to 5 bar Received Signal Strength Indication (RSSI).
  • Mobile networks no longer disabled when using Power Saver.
  • Device is enabled with the Wireless Alerting System.
Device Dock Features
  • Default applications in Dock Mode have been changed to “Phone” and “Calendar”.
  • In-call volume control has been added to Dock Mode.
  • “All Apps” option has been added to Dock Mode.
  • Resolved issue of dock volume changing to 20%.
Applications & Widgets
  • Device displays available music on the device and provides an option to purchase ringtones from the MOD application when a user is attempting to set a new ringtone through a pre-populated list.
  • Mail shortcut now shows unread mail count
Verizon is set to push this update out "soon" so that means keep checking manually for the update, and be sure to let us know how the update goes for you! Full details about the new firmware, and update procedure are available at the source link below.
Source: Verizon Wireless
Be the first to comment!
