Grab Choetech's USB-C cables at Amazon for $7
If you're still looking to add some more USB-C cables to your arsenal, you'll want to check out this deal from Choetech which drops them as low as $7 per cable. Choetech is offering savings on both the USB-A to USB-C as well as USB-C to USB-C cables in various lengths. You'll need to use a coupon code for the savings here, and the codes vary depending on which cable you are interested in. The deals are:
  • AC cable (6.6ft): $6.99 with code L3JGFC9V
  • CC cable (6.6ft): $6.99 with code B3JCFC9D
  • AC cable (9.9ft): $7.99 with code WTZ35GDZ
  • CC cable (9.9ft): $7.99 with code A8EPELJF
  • Bundle deal: AC cable 3.3ft + CC cable 3.3ft = $11.99 with code SLK7DSFC
To get the bundle deal, you'll need to add both cables to your cart separately, and then use the coupon code above to score the savings. Should you also find yourself needing a USB-C Fast Charging wall charger, Choetech is offering this one for just $13 with coupon code ZCU2CZDC. We are not sure how long this deal will last, so if you're interested don't wait too long.
See at Amazon
