Best smart lights for gaming 2024
Game in style with the best smart lights out there.
Smart lighting isn't just limited to turning your bulbs on and off from your phone or changing their colors by asking Alexa. With modern technology they can actually react to the media that you're viewing, whether it be television or movies. And they aren't just limited to passive experiences, either.
With the best smart light bulbs, you can even soup up your gaming rig with lights that follow the rhythm and beats of your games, turning your entire room into a living visualizer. These are some of the top smart lights for gaming to consider.
The best smart lights for gaming
Start simple
If you don't already have an elaborate smart lighting rig, why not start simple with a couple of bulbs? You can start with one, two, or however many Philips Hue White and Color Ambiance bulbs you want and connect directly to your phone via Bluetooth. No hub needed. Philips Hue partners with gaming brands like Razer so that your lights can match the changing colors of your Chroma-powered peripherals.
Connect to Razer Chroma
Just like the light bulbs, Philips Hue's LightStrip Plus can connect with Razer Chroma devices like Razer's RGB gaming mice and keyboards and match their colors to give a unique ambiance to your room. You can stick this top light strip to the bottom or edges of your desk, the trim along your walls, or anywhere else that might look interesting with a colored glow.
Display lighting
Maybe you prefer shining colored lights onto your wall instead of emitting them from a lamp or the back of your desk. The Hue Play light bar is yet another smart light system from Philips Hue that is sold individually or comes in a pack of two and sits tilted on your desk to shine light onto your wall — it works especially well with both lights pointed behind your computer monitor.
Reacts to sounds
Though Nanoleaf's standard kit isn't properly equipped for gaming, the Rhythm Edition kit includes a sound module that listens for music and features a specialized game mode that reacts to various in-game sounds. Like Philips Hue, Nanoleaf smart lights work with Razer Chroma, along with Cooler Master, to color match your gaming peripherals.
Wi-Fi controlled
The LIFX Light Strip is a long strip of dimmable LED lights with rich color combinations and effects. You can control it with your phone and select from any of LIFX's preset themes or create your own, and it ties in with Razer Chroma as well. It connects to your Wi-Fi, so you can control it even when you're not home.
Keep it cool
While you're lighting up the setup around your gaming rig, why not colorize your computer tower itself? The 120mm RBG 2 fan from Nzxt comes in a single, two, or triple-pack and keeps your computer cool — in both senses of the word. You can daisy chain multiple fans together to create different lighting effects.
Blacklight immersion
Govee's Immersion TV Backlight uses ColorSense technology and a 1080p HD camera to capture the colors on your screen and apply them to your backlights, creating a truly immersive gaming experience. In addition to customizing each light segment, you can also sync your lights up to your music and pick from several different modes like game mode.
Create custom designs
Nanoleaf's latest smart light bars will add a cool flair to any living room or gaming space. Nine individual pieces shaped as lines connect to one another at 60-degree angles, letting you create the custom geometric shape or design of your choice. Featuring dual-color zones, these light bars are capable of syncing up with music in real-time as well as screen mirroring for an immersive gaming experience.
It pays to stay within an ecosystem
Matching the color and intensity of your lights to your games and peripherals can make a surprisingly noticeable difference in your gaming experience. For example, bouncing colored lights off the wall behind your monitor can add to the ambiance of your game and even ease the strain on your eyes by keeping the amount of light relatively even between your foreground and background.
Most of the best smart lights for gaming support standards like Razer Chroma, which allows them to change color along with your game without needing any extra setup on your end. Philips Hue's White and Color Ambiance bulbs are the most popular and best Philips Hue bulbs and work great with Chroma. Once you have one Hue product, why not keep going with more and more lights from the lineup? The best part: while Hue lights used to require a hub to control, they can now operate independently over Bluetooth.
LIFX is another great smart home brand whose lights don't require a hub connecting directly to your Wi-Fi network. If you're after something unique, Nanoleaf's Rhythm Edition light panels or new smart light bars can be arranged any way you like for a truly personal setup.
Be an expert in 5 minutes
Olivia Lipski is a freelance writer for Android Central and loves testing out the latest smart home tech and discovering the best cell phone plans. When she's not busy running around NYC trying to find great food or coffee, she's in her kitchen trying to make it herself.
