inc 2 battery 1
The HTC Droid Incredible 2 boasts pretty solid stock battery life. I haven’t needed to make adjustments in order to make it safely through a day. However, there are times when you’re using the device all day and into the night and just need that little bit of extra juice. If you’re looking for a battery that will give you a tad better battery life but not require another case, check out the Seidio Innocell 1750mAh Slim Extended Battery.
The Incredible 2 comes with a 1450mAh, which does an admittedly good job. It’s always good to have more power though and without needing an extra case there’s really little downside. The battery life will not blow you away; you won’t be able to use it for 2 days straight with heavy use. What it will do is assure you that, even with heavy use, you won’t need to think about it during the work day. I’ve used Amazon’s Cloud Player to stream a lot of music for an extended period of time and the battery has still performed very well.
I reviewed this extended battery with the Incredible 2, but it is also compatible with the Incredible S, EVO Shift 4G, Desire Z and T-Mobile G2.
If you’re interested in adding some extra power to your phone, the battery can be had for $47.95 from the Android Central Store. More pictures after the break.
 inc 2 battery 2   inc 2 battery 3
inc 2 battery 4   inc 2 battery 5
Be the first to comment! Login or Register now!
